Not display colors RGB only shades red and yellow
The fit-pc2-series c1600-h-w-xl 090802 011 the video card does not display all colors RGB (red, green, blue), only shades of red and yellow. For the various tests were used HDMI to DVI adapters including the one that came with it.
Re: Not display colors RGB only shades red and yellow
This is a problem with signal integrity on some HDMI signals.
Before RMA double check that the problem is not with the cables or with the connector on the display.
Hello good day,
As the HDMI to DVI adapter I used the first that came along with FIT-PC2, identified the problem really was contemplated that it was the adapter. I purchased a HDMI to DVI philips, remains the same problem of display colors. Could you indicate some other adapter? Preferably it is straight to the monitor to avoid unnecessary amendments. Or technical assistance that can send the fit-pc2 here in Brazil.
Check your display with another computer.
If OK then contacts or soldering inside the fit-PC2 must be damaged.
