Page 1 of 2
Installing drivers for win7
Posted: Wed Jul 03, 2013 8:36 pm
by mimosa
How do you tell which ones are needed? For instance, there are two for ethernet, and others where the function isn't obvious (ME).
Re: Installing drivers for win7
Posted: Mon Jul 08, 2013 9:16 am
by sorin
Maybe this post will help:
http://www.fit-pc.com/forum/viewtopic.php?f=93&t=2914
Also, the serial port drivers are in the ME file which must be installed using Update Driver.
Posted: Mon Jul 08, 2013 10:27 am
by mimosa
It helps up to a point. Thank you. But it would be great if you could provide clear instructions on the download page or linked from there.
I didn't understand what you meant about how to install the ME driver. Is this some feature of Windows?
I should say that I have very little experience with Windows, being generally a Linux user.
Posted: Mon Jul 08, 2013 10:46 am
by sorin
Yes, they should put some instructions somewhere where people can clearly see what to do. I am just a user and I have problems installing the video driver on my IntensePC. Browsing the forum I found that post that helped me install the drivers on the weekend.
The "Update Driver" is a menu option if you right-click a device in Device Manager. The Serial port in my case showed two devices with a yellow question mark icon. Right-click on one of them and select "update driver". In the dialog box, navigate to the folder where the unzipped files from the download are, and Windows will select the appropriate driver.
Posted: Mon Jul 08, 2013 11:45 am
by mimosa
Thanks Sorin. Sorry, I thought you were support staff!
Posted: Wed Aug 14, 2013 9:10 pm
by mimosa
Installation of the video driver (32 bit) failed, with a typically uninformative Windows message.
I also tried using Update driver, but it says the video driver is up to date. The video "hardware" that appears there looks like some generic thing, with no GP or anything like that.
How should I proceed?
EDIT Here is more detail on the failure, when I try with the latest driver from the intel website:
Problem signature:
Problem Event Name: APPCRASH
Application Name: Setup.exe_Intel(R) HD Graphics
Application Version: 1.5.25.0
Application Timestamp: 5131566b
Fault Module Name: Setup.exe
Fault Module Version: 1.5.25.0
Fault Module Timestamp: 5131566b
Exception Code: 40000015
Exception Offset: 0003e145
OS Version: 6.1.7600.2.0.0.256.48
Locale ID: 1046
Additional Information 1: 67d9
Additional Information 2: 67d918b5d2dc6eb7485f13ad2e1b79c1
Additional Information 3: 0059
Additional Information 4: 0059ca11f4961b0cc8cd15cde7d70c7c
When i follow these instructions to identify the hardware:
http://www.intel.com/support/graphics/sb/cs-009482.htm
I see "Standard VGA graphics adapter" rather than the expected
Intel (R) HD Graphics 4000
Also, under "Device manager", the display appears as a "Generic PNP Monitor"
Posted: Sun Aug 18, 2013 12:15 pm
Please go to Start Menu, right click on "Computer". Left click on properties. Please send me a print screen of the windows to PM.
Posted: Sun Aug 18, 2013 3:40 pm
by mimosa
Thanks for getting back to me, gabrielh.
I can't see how to attach something to a PM but I uploaded the screenshot here:
http://people.salixos.org/mimosa/misc/shot.png
As you can see, for the time being I'm using 32-bit Windows, but I hope eventually to get 64-bit Windows and make the most of the hardware.
Here is what Linux has to say about the GPU:
root[mimosa]# lspci -v -s `lspci | awk '/VGA/{print $1}'`
00:02.0 VGA compatible controller: Intel Corporation Ivy Bridge Graphics Controller (rev 09) (prog-if 00 [VGA controller])
Subsystem: Intel Corporation Device 2211
Flags: bus master, fast devsel, latency 0, IRQ 48
Memory at e0000000 (64-bit, non-prefetchable) [size=4M]
Memory at c0000000 (64-bit, prefetchable) [size=512M]
I/O ports at 4000 [size=64]
Expansion ROM at <unassigned> [disabled]
Capabilities: [90] MSI: Enable+ Count=1/1 Maskable- 64bit-
Capabilities: [d0] Power Management version 2
Capabilities: [a4] PCI Advanced Features
Kernel driver in use: i915
... does that look to you as though all is as it should be?
Posted: Wed Aug 21, 2013 10:43 am
As I see, you are trying to use a 8GB of a system memory on a x32 system. You will not be able to use more then 3 GB of it ... Win7 x64 will let you to take advantage of all the 8GB of the memory
Posted: Wed Aug 21, 2013 11:30 am
by mimosa
I don't understand. The problem is with the video. Please see my previous post, the screenshot you requested, and the output from lspci using Linux on another partition. That looks to me as though everything is fine there, but in Windows, it isn't, the video driver doesn't work.
Please see also the post I originally made describing the problem, to which you replied requesting the screenshot.
To be doubly clear: installation of the (32 bit) video driver fails.
