Do the rear USB ports come off the same hub?
csimon
Post by csimon »
Do the two rear USB 2.0 ports come from an internal hub (and therefore share bandwidth) or are they separate?
Also wanting to find out if plugging in a slow device (e.g. keyboard) to one of them will cause the other to go at the slower speed.
Re: Do the rear USB ports come off the same hub?
Intense PC features separate USB Host controller (on the same chipset) per USB port, therefore any USB port can supply full USB throughput.
csimon
Post by csimon »
Brilliant, thank you!
Return to “USB”
