FITVGA output problems
Alex1
Post by Alex1 »
Hi , just purchased a FIT-PC2i with HDMI to VGA adapter ( FITVGA) .The OS on the FIT is win 7 32bit .
I am sure someone asked this already , sorry if they have .
The problem i am having is that when i connect the PC2i and FITVGA to a 17 inch rack mountable LCD screen , i can see the os booting but nothing once the windows screen has loaded .I have tried a second VGA monitor and this works fine . On default VGA drivers the rack mountable screen works fine but the res is to low , i have been on the intel web site and rolled the driver back to 2026 but same problem .
Re: FITVGA output problems
Seems not to be a HW problem with any of the devices. Maybe the non-working VGA display cannot sync on the resolution/refresh rate selected by the driver. I suggest you try to force a lower resolution.
